QUOTE(Chris Hamilton @ Jan 30 2010, 12:26 PM)
I've had a few batteries from Braille and not had very good luck with them. I would not recommend them. 2 x 6lbs ones stopped charging and a larger one cracked and started leaking.
I would also recommend that you check out Deka batteries as they have a few that look identical to the braille, I suspect braille is just taking those and relabeling them.
I do however like the optima yellow top batteries. I have a few of those that have lasted more than 10 years, and only one failure out of the 7 that I've bought.
Thanks for the comment, Chris.
How did all the crack and leak happen to your larger Braille? Hope those were covered by warranty. I might want to pass Deka since it's not popular among the 914 world. I would take the red top(35) if Optima. The yellow top is lighter and more compact than the other but I don't think it will clear the rain tray. How's yours?
BTW, are you running a shop in Berkeley?
