wheelboy
Feb 1 2010, 09:18 PM
Hello, can you guys tell me if I can put a little more power on a 1.7FE
jmill
Feb 1 2010, 09:31 PM
Depends on how much you want to spend. How about building it into a 1911? Or are you hoping to tweak a couple of screws and pick up 20 hp?
http://www.914world.com/bbs2/index.php?sho...891&hl=1911
wheelboy
Feb 2 2010, 07:50 AM
What I need to make it a 1911?? but I want to keep my FE!!!!
ME733
Feb 2 2010, 08:32 AM
.............Well ....heres an Idea for an upgrade....replace ALL the rubber, flexable, FUEL lines including those short lines to the injectors. Inspect the fuel tank lines and connections. clean gas tank, and micronic-in-tank filter. Check the fuel pump pressure....replace the other fuel filter. After the fuel system has been rebuilt, you may notice a performance increase.BUT MAINLY, you will know that your car will not burn to the ground ,do to a faulty fuel system......I.M.O.
