QUOTE(yeahmag @ Feb 9 2010, 02:16 PM)
A friend just picked up a late '74 2.0 with the factory DJet. We've replaced the fuel filter as it looked gnarly and are getting ready to ohm out/replace the temp sensor, but I found something strange.
The car will not start at all with the temp sensor disconnected. I thought it might run rich with it disconnected (an improvement from where we are now), but I never thought it would fail to start.
Is that to be expected? Any place to look for lean conditions across the board other than:
* CHT
* Fuel Pressure
* Idle mixture knob (all ready fully rich)
Gonna go through the entire FI/Ignition system top to bottom, but just thought I'd ask. That CHT thing is weird too...
When the CHT is open, the injection pulse durations are extremely long (>40 ms), making the mixture too rich to start.
First, what makes you believe that it's running lean? I assume this is with the car fully warmed-up? What is the idle CO? Can you measure CO while running at part-load? Just checking to make sure you're going after the right problem.....
If it really is lean, a possible reason is that someone has "adjusted" your MPS part-load to a lean mixture. Do you have a spare MPS to swap with it? Very low fuel pressure is another possibility. Idle mixture knob only affects mixture when the throttle is closed (idle and overrun conditions).
