Markl
Feb 9 2010, 09:19 PM
OK, here's the thing - I took the car out for a short spin without the air pump belt - when I came back, the pulley had disappeared! I swear. this car is going to kill me! Anyway, I need one to get through the air test. Small pulley, threads (as I remember) onto the alternator shaft. I would prefer one that is not considered rare and extremely valuable, just plain old rusty steel, like the rest of the car. Thanks!
bdstone914
Feb 10 2010, 08:22 AM
The air pump pulley is driven off of the fan by a shaft. If that is what you lost I dhould have one. I have not looked to see how they are attached to the shaft.
Bruce
jk76.914
Feb 10 2010, 05:09 PM
Here's a pic. Its a 912E, but you can see the setup. There's a steel tripod of sorts, bridging left, right, and top of the fan. The tripod holds a bearing, in which spins the shaft. Can't remember, but I think there's a rubbery connection to the hub of the fan.
Good luck.
MY question- where does the a/c compressor fan go with this setup???
Markl
Feb 10 2010, 10:12 PM
Thanks for the info. My '75 2.0 must have a 'custom' setup! The belt ran from the air pump over to the alternator, which had a second, smaller pulley frontwards of the alternator pulley. Really, I'm not crazy, I moved it over when I put in a new alternator.
Oddly enough, I have the proper fan pulley, just didn't know what it was! Guess I'll put it on and go from there.
As far as the A/C goes, I've wondered about that myself, so no help here.
bdstone914
Feb 10 2010, 11:46 PM
It you want the correct pulley setup I have a good one. Do you have to run the air pump in CO? I not do away with it.
Bruce
boxstr
Feb 13 2010, 08:28 PM
Here is the pulley I found. Not sure if this what you need or not?
Craig C. Laughlin CAMP 914
Markl
Feb 13 2010, 09:46 PM
The pulley I lost was attached to the alternator - I have the correct setup, I just didn't know it! Thanks for the help, all.
McMark
Feb 16 2010, 09:44 PM
Craig, that's an AC pulley that goes between the fan and the crank, behind the impeller housing.
boxstr
Feb 16 2010, 10:10 PM
Mark Thank you for the info. I will catalog it.
Craig
