QUOTE(ClayPerrine @ Feb 10 2010, 08:11 AM)
Piker....
Betty has 335,000 on her 1.8L.
The 1.8L is not known for dropping valve seats, there is more meat around the valve seat area. And the Type IV bearings are not normally prone to spinning, unless they are run without oil.
Rebuild when the rings wear out and it starts sucking oil. New pistons and cylinders, new bearings, new oil pump, new cam and lifters. Do a valve job and you are good to go for another 150,000.
My poor 1.7 is pushing 180,000 and its time. I have a rebuilt 2.0 liter going in its place. What I see is rings and valve guides are normal wear items.
Once you start, replace everything and your good for another 200k.
The oil suck/burn is the time to start thinking about it.
Rich
