So, what tool do you guys use to loosen/tighten the allen head bolt thats circled (in the borrowed picture). The expansion tank is in the way. A realy long allen wrench with a short leg?
Take the exp. tank off. Two small bolts on the back side IIRC.
r_towle
Feb 10 2010, 12:01 PM
remove the tank...its a five minute job. Whatever you do, dont use a pipe wrence or vice grips. Rich
Phoenix-MN
Feb 10 2010, 12:05 PM
QUOTE(r_towle @ Feb 10 2010, 10:01 AM)
I guess thats the route I'll take. It's just a pisser to have to take things apart when you've just put it all together
Thanks
yeahmag
Feb 10 2010, 12:09 PM
Those bolts are a real pain in the butt for being two 10mm bolts... I hate putting that thing on and off. I've been tempted to work out *any* other solution.
Phoenix-MN
Feb 10 2010, 01:45 PM
QUOTE(yeahmag @ Feb 10 2010, 10:09 AM)
Well, an extreme solution would be to drill a 3/4" hole in the right palce on the expansion tank and weld in a tube to pass a long allen wrench through... ala a 911 heat exchanger
andys
Feb 10 2010, 02:10 PM
I'll have to look at my car, but I don't recall this being a problem with the plastic expansion tank ('75).
Andys
r_towle
Feb 10 2010, 02:28 PM
10mm socket, long extension...5 minute job Once you set your alignment you are done...no need to play with it unless you are swapping tires for an autox. Rich
