Couple of engine build questions:
1. When determining deck height, you assemble the piston and cylinder onto the rod. Because you will need to remove the P/C from the rod during final assembly, am I correct that there is no need to install the rings during this procedure? Is it necessary to install the wrist pin retainers? I’m not sure if there’s a chance the wrist pin could move and score the cylinder wall.
2. When determining pushrod length, assuming you have a dual pattern camshaft, once you’ve determined the pushrod length for the intake and exhaust on one cylinder, is it necessary to do the same procedure for the other 3 cylinders, or can you just cut all the exhaust pushrods to that length and the same for the intake pushrods?
