I'm putting together an 1835 I had in my Baja years ago, before I knew what I was doing. I originally used Weber progressive which in hindsight I realize was the main reason I melted number 3.......twice The case is a VW f.i. case, lign bored by one of the best around here, heads WERE stock, That's where my ? comes in. I know when I used to be into VW's hardcore the 041's were the things for a mild streeter. Now with the advacements of the last 15 years what is recommended ? 044's? How about carbs ? 40 IDF's ?
I'm well aware of the issues with 92's but I already have 2 1/2 sets of near new ones so that is what I will be using.
What I have for it :
c.w. 69 mm crank
92mm Mahles
Engle 120 cam
balanced stock rods ( unless someone has something nicer for a good price )
full flow
high flow pump
sump
extractor from a Euro high tuck system, will probably run a stinger on it
Heads ???
Carbs ?????
other suggestions ??????
