QUOTE(Cap'n Krusty @ Feb 15 2010, 06:12 PM)
Oink. If it's from around your area, it's rusty. Everywhere. While replacement sheetmetal is relatively available, costs of replacement are apt to be high. Exhaust components are pricey, and usually hosed. The vacuum system that runs nearly everything is complex and leak prone. The CIS system is prone to vacuum leaks, and the components are a bit pricey and time consuming to replace. It's probably due for an alternator and possibly a PS pump and steering box. The front end and subframe will need to be rebushed and the steering linkage is probably shot. They're heavy and they don't handle like a sports car because they AREN'T a sports car. I'm just thankful there aren't very many around here anymore, because I really don't like working on them.
The Cap'n
Thanks for sharing your knowledge Cap'n. I believe I will pass on this one.
