QUOTE(craig3x @ Feb 17 2010, 12:11 AM)
QUOTE(detoxcowboy @ Feb 16 2010, 08:04 PM)
fuse box plate under dash, take out the 2 screws and it comes down, orginal high/low relay is a silver cube to the left mounted upside down.. it may be black plastic cube still mounted upside down.. with wires going to and from it yellow and whitwires ect. ect.. usually when the fail you can't click lock into high beam but fail is fail.
hmmm, well mine is stuck on and won't click back to low. could this still be my problem? anyone have a picture of it's mounting location?
I would bet the relay is faulty, sorry for the extra input as that confused the matter, easy as replacing a fuse, drop the fuse box 2 screws you cannot miss it or mistake it.. only one mounted upside down...
