zonedoubt
Feb 17 2010, 02:55 PM
I'm having a hard time finding replacement hose for the drain tubes that come off the bottom of the fresh air hose. Mine are brittle and cracked. I've tried hardware stores and hose supply shops, but nothing fits. The ID is slightly under 1". I remember seeing a post about someone finding a corrugated irrigation hose that fit and even looked correct. Does anybody have some hose they can spare?
Sleepin
Feb 17 2010, 03:06 PM
Bummer! I sold a set a couple months ago that were OEM and in great shape...they went for $9.14....
bandjoey
Feb 17 2010, 03:29 PM
Lowes has a rack of various size hose. Try there or an Ace hardware type store.
zonedoubt
Feb 17 2010, 03:47 PM
We don't have Lowes or Ace here. I've been to Home Depot, Rona, Canadian Tire, WestMarine, and a fitting and hose supply shop. The closest I got was 1-1/8" ID bilge hose but it's too big, bulky, and won't fit through the hole in the bottom of the fuel tank bay.
QUOTE(bandjoey @ Feb 17 2010, 01:29 PM)
kconway
Feb 17 2010, 03:56 PM
Is this a different size then the engine drain tubes/funnels?
Kev
Sleepin
Feb 17 2010, 04:19 PM
I am pretty sure that it is exactly the same Kev.
markb
Feb 17 2010, 04:33 PM
QUOTE(Sleepin @ Feb 17 2010, 02:19 PM)
zonedoubt
Feb 17 2010, 04:41 PM
In any case, they're NLA right? What are people using to replace their 35+ year old drain hoses?
VaccaRabite
Feb 17 2010, 04:57 PM
I used the 1.25 inch bilge hose, and gave it a taper cut at the bottom to push it through the hole under the tank. Put a little sealant on the cut, and it was good to go.
Zach
shoguneagle
Feb 17 2010, 05:10 PM
I found the proper size of rubber hose and replaced all the plastic connectors (cracks very one of them) with brass fittings (straight and 90 degree along with a brass tip at the bottom. A little bulky but seems to work very nicely. These are out of sight and I am not really concerned with originality.
zonedoubt
Feb 17 2010, 05:37 PM
I was thinking of going with clear tubing or maybe try to use the bilge hose I have. That means shimming the air box fittings and to fit the hose and use gear clamps. I was hoping for a more elegant solution.
Any problems getting the gas tank in with bulkier hose?
VaccaRabite
Feb 18 2010, 06:53 AM
QUOTE(zonedoubt @ Feb 17 2010, 06:37 PM)
Nope.
kconway
Feb 18 2010, 09:07 AM
QUOTE(zonedoubt @ Feb 17 2010, 02:41 PM)
Well...In this thread a year ago you said you found a solution.
http://www.914world.com/bbs2/index.php?sho...302&hl=hoseI bought mine here: http://www.greenlinehose.com/
"G930… CORRUGATED BILGE HOSE"
$0.60/ft and has a nice "clamping cuff" to fit over the funnels. It is a bit wider diameter but is a decent solution.
Check your local Yellow Pages for hose suppliers.This appears to be available only through websales on the Home Depot site:
http://www.homedepot.com/webapp/wcs/stores...=10000003+90401
zonedoubt
Feb 18 2010, 12:22 PM
QUOTE(kconway @ Feb 18 2010, 07:07 AM)
Yes...but that was for a solution to the engine lid drain tray hoses. They work OK for that. But in the air box application, they seem too bulky with gear clamps and trying to fit behind the gas tank and through the hole in the sheet metal.
http://www.homedepot.com/webapp/wcs/stores...=10000003+90401...in the USA only.
kconway
Feb 18 2010, 12:33 PM
QUOTE(zonedoubt @ Feb 18 2010, 10:22 AM)
Go directly to the source.
http://www.888beckett.com/product_catalog/...subsubsubnav=18
zonedoubt
Feb 18 2010, 12:37 PM
QUOTE(kconway @ Feb 18 2010, 10:33 AM)
I came across that in my exhaustive search.
20 ft would be enough for 10 cars. Not to mention the shipping costs, even if they sell direct to the public. What I'm hoping is someone already has a roll of this and can cut off a few feet for me.
Mikey914
Feb 18 2010, 02:39 PM
I'll bring in a roll and make availabe to those that want it. I look at about a 15% premium, but it's better than sitting on a buch you will not need. I'll also combine with any orders for other stuff you might need
zonedoubt
Feb 19 2010, 06:56 PM
I actually found some at the local gardening shop this afternoon. Funny...just when I thought I'd never find what I was looking for. Looks pretty damn close to the original tubing. It came in a 25' roll but I figure some of you might need some. I'll post some pics when I get it installed.
zonedoubt
Feb 23 2010, 07:24 PM
zonedoubt
Feb 23 2010, 07:25 PM
zonedoubt
Feb 23 2010, 07:27 PM
Engine lid tray drain hoses...
tomeric914
Feb 23 2010, 08:41 PM
Nice! Who is the manufacturer of that hose?
