yeahmag
Feb 19 2010, 03:47 PM
I've been through my brakes a million times and I'm still not satisfied with the pedal height. I'm 99% sure everything is correct except the MC push rod. It feels like I have a good 1" of pedal travel before it touches the MC.
Anyone have an idea what the proper clearance procedure is?
-Aaron
McMark
Feb 19 2010, 04:02 PM
The pushrod attached to the pedal is adjustable. There is a lock nut you loosen and then twist the rod to length/shorten it.
yeahmag
Feb 19 2010, 04:04 PM
Thanks! Just didn't know what the value was. I'll check that it's 1mm.
Cap'n Krusty
Feb 19 2010, 04:59 PM
You're gonna have to get down there and feel the play with the ol' Mk1 fingertips.
The Cap'n
yeahmag
Feb 19 2010, 05:01 PM
Yeah... I'll try shoving my fingers through the AL board I have first and see if it's close or not. If I could get that free play at the top of the pedal down a bit I'd be happier...
McMark
Feb 19 2010, 05:44 PM
If'n ya pay real close attention, you can push the pedal and feel the pushrod hit the MC plunger/piston. 1mm at the pushrod doesn't equal 1mm at the pedal, but you can make an approximation in your head.
yeahmag
Feb 19 2010, 05:48 PM
*Assuming* it's a 1.25mm thread pitch I could also run it in until it just touches and then back it off one turn.
McMark
Feb 19 2010, 06:23 PM
Yup!
