... unless you're looking for used? .....
IIRC Restoratio Sheet Metal (name??) a vendor on here, is doing that very part again, now that they moved the factory over to Ontario CAN. They're listed in the member vendor section here.
Also get the L&R Tailight seals & F&R rear trunk seals so it won't reoccur. Mark at Mikey914 - another member vendor here does those too.
Good Luck & Cheers!
Tom
