I've had my gages out for a while. Just putting my interior back in the LE. Went to do the gages & while there are only so many options. There are a few different combinations. Meaning I would probably get them wrong. Figured to see if anyone had a diagram for them
rick 918-S
Feb 20 2010, 05:25 PM
QUOTE(JRust @ Feb 20 2010, 05:20 PM)
I think there are diagrams on the bird board. I think...
Todd Enlund
Feb 20 2010, 05:26 PM
QUOTE(JRust @ Feb 20 2010, 03:20 PM)
I was hoping for a nice picture of the backside hooked up . Using that wiring diagram will take brain power . Everyone should know by now I am in short supply
JeffBowlsby
Feb 20 2010, 08:13 PM
Ya mean like this here? From my 914 Classic site:
JRust
Feb 20 2010, 08:22 PM
QUOTE(Jeff Bowlsby @ Feb 20 2010, 06:13 PM)
Yes Jeff that is perfect! Thanks
I pulled the gage partially out on my 73. Only problem is the combo gage is different. So I did need this for that one.
watsonrx13
Feb 21 2010, 06:58 AM
Jamie, this is the diagram I made for my '74, hope it helps.
I got it off of Jeff's diagram. Thanks for all the help guys. Still a ways from being able to actualy test it . It is hooked up right though thanks to your help
flipb
Mar 9 2010, 01:00 PM
My gauges have some wiring quirks that I'm hoping to address soon. This thread will be a great help.
Two quick questions:
1. I know of at least one wire back there that shorted out and melted its sheath... What gauge wire do I need to replace it?
2. Is it necessary to remove the dash bottom to access the various electrical hookups on the headlight switch?
The extent of my electrical experience has been replacing fixtures and outlets in my house. Appreciate any additional tips for the clueless.
McMark
Mar 9 2010, 01:38 PM
1. Most wires are 18g, but some are larger. 2. The headlight switch has a lot of connections. If you drop the relay panel (two screws), unscrew the knob and then unscrew the escutcheon (the small aluminum ring) which holds the switch onto the dash, you can then pull the switch down enough to see what is what.
nivekdodge
Jun 16 2022, 08:03 PM
QUOTE(Jeff Bowlsby @ Feb 20 2010, 10:13 PM)
Jeff I have a dash and chunk of harness out of a 72 that im going to try to wire into my 74. will the wire colors match up?
Different gauges, different wiring
GeorgeKopf
Jun 29 2022, 07:09 PM
QUOTE(JRust @ Feb 20 2010, 05:44 PM)
