EdwardBlume
Feb 22 2010, 11:34 PM
Check out the ride height between the racer and the stocker....
This is going to cut deep, the more I work on this thing, the more I want to make it "perfect" ..... naw, just kidding, 914s are meant to be driven!
EdwardBlume
Feb 22 2010, 11:35 PM
914 Art...
rick 918-S
Feb 22 2010, 11:53 PM
Jeeeze!
I'll be over in March to see it!
EdwardBlume
Feb 23 2010, 12:00 AM
See it? You mean work on it?
You can see the sights too.... (from Coit Tower in SF and Lombard St)
rick 918-S
Feb 23 2010, 12:19 AM
Work on it? Hell ya! I'll have my son with too!
oldschool
Feb 23 2010, 02:19 AM
QUOTE(rick 918-S @ Feb 22 2010, 10:19 PM)
Rick,so.....stop by my place and help me 2
KELTY360
Feb 23 2010, 02:58 AM
Quote # 10,000 and there wasn't even a marching band. You da man Rick
Edit: Never mind.
The Real 10K Post
EdwardBlume
Apr 4 2010, 09:38 PM
Progress progress..
EdwardBlume
Apr 4 2010, 09:39 PM
Getting the buckets in..
EdwardBlume
Apr 4 2010, 09:40 PM
This is how it should look..
EdwardBlume
Apr 4 2010, 09:41 PM
How hard can this be?
EdwardBlume
Apr 4 2010, 09:42 PM
It was tough enough...
EdwardBlume
Apr 4 2010, 09:44 PM
Moving to the interior... 2 years out it got a little weathered, but the steering wheel should still feel good after some work...
EdwardBlume
Apr 4 2010, 09:45 PM
Clean the carpets... yes that's doggy shampoo... leaves a nice shine plus conditions..
EdwardBlume
Apr 4 2010, 09:47 PM
Ended up soaking the carpets in OxiClean for 2 days with 4 washes... came out... crappy.. will need new carpet soon...
EdwardBlume
Apr 4 2010, 09:48 PM
Working on the engine bay...
EdwardBlume
Apr 4 2010, 09:51 PM
Engine lid pull cable was rusted and broke... the tube is shot, and may have been a "tech tip" ground as it was fused to the tube... free the rusted cable took a chunk of the tube off... bummer...
grantsfo
You know whats funny? That race car was nicer than that stocker 6 years ago..
EdwardBlume
Apr 4 2010, 09:53 PM
Next is how to install the stainless fuel lines.. do I really need to jack the car up off the pass side to feed the tube in?
EdwardBlume
Apr 4 2010, 09:55 PM
QUOTE(grantsfo @ Apr 4 2010, 07:51 PM)
It shows.. I've actually taken some parts off of it... like the window squeezgies on the doors to use on my car...
rick 918-S
Apr 4 2010, 10:00 PM
Nice work Rob. Wished I had time to visit when we were soooo close! Keep up the good work! And change that carpet
DanT
Apr 4 2010, 10:02 PM
looking very nice Rob.
I plan on putting new carpet in my '75 once I get it back from the body shop...
whenever that will be.
time to call Morph...
EdwardBlume
Apr 4 2010, 10:04 PM
Its amazing what 30+ years of gas fumes, oil and coffee stains do to the OEM carpet. I would LOVE a plush black carpet kit like the stuff used in my old 993.. you know that really soft stuff....
EdwardBlume
Apr 4 2010, 10:07 PM
The "OEM" antenna doesn't sit right... am I missing a part? I'm thinking of just adding a rubber and metal washer and trying to get it to sit down...
rick 918-S
Apr 4 2010, 10:10 PM
There should be a contoured spacer under the fender to align it.
DanT
Apr 4 2010, 10:22 PM
Rob you are missing a rubber grommet that sits between the fender and this eccentric piece in the pictures...
the eccentric piece allows the antennae to sit on a surface that is not level and let you get that antennae straight up and down. the nut then tightens down onto the eccentric piece.
hope these help.
hot_shoe914
Apr 4 2010, 10:39 PM
QUOTE(RobW @ Apr 4 2010, 10:41 PM)
Not all that tough if you have a ninja trunk monkey!
EdwardBlume
Apr 5 2010, 07:20 AM
QUOTE(DanT @ Apr 4 2010, 09:22 PM)
hope these help.
Thanks Dan! these help a lot.... now if only I can remember if I lost it in 1988 or 2008?
brant
Apr 5 2010, 07:27 AM
nice work Rob!
Al Meredith
Apr 5 2010, 10:00 AM
Nice work, I love the color....check out my avatar.
EdwardBlume
Apr 5 2010, 09:14 PM
I forgot to post picts of the doors... these took me awhile, but thanks to Mikey they look pretty good... and should work now....
EdwardBlume
May 22 2010, 05:38 PM
Out for some sun today... yep, that's the engine installed...
EdwardBlume
Jun 8 2010, 08:02 AM
Rust treated and BBQ painted.... it came out flat black instead of shiny black, but then again its a factory stock and weathered muffler...
EdwardBlume
Jun 8 2010, 08:03 AM
Can the steel tip be polished? How?
914Sixer
Jun 8 2010, 08:10 AM
You can try polishing it out with a coarse and then a fine wire wheel. Then try some polishing compounds on a buffing wheel. Going from coarse to fine.
DanT
Jun 8 2010, 08:26 AM
looking good Rob.
Yes that tip can be polished, but it will take some time and elbow grease
McMark
Jun 8 2010, 09:30 AM
Looking great!
underthetire
Jun 8 2010, 10:14 AM
QUOTE(RobW @ Jun 8 2010, 07:03 AM)
Nice. And you can use a scotch brite disk on a die grinder to get it close for final polish. H/F sells them super cheap with different grits. I probably have one if you need it. If it's a steel tip won't stay polished long, stainless on the other hand is very nice.
Drums66
Jun 8 2010, 01:01 PM
QUOTE(RobW @ Feb 22 2010, 10:34 PM)
Rob...Rob...you're cured!!!....it's a miracle.. LOL
P.S. that's a cool color(I had 1 in the past)
EdwardBlume
Jun 8 2010, 03:36 PM
QUOTE(Drums66 @ Jun 8 2010, 12:01 PM)
Close to cured. I still need to connect the clutch, install the center console, connect the half shafts, install the vacuum lines, gas tank, battery, and engine lid....then there's the brakes, suspension.. it goes on and on...
Getting close for sure...
EdwardBlume
Jun 14 2010, 07:21 AM
Polished the exhaust tip and got the muffler installed. Also finished connecting the vacuum lines...
krazykonrad
Jun 14 2010, 03:43 PM
That is one nice looking ride!
Konrad
Mike Bellis
Jun 14 2010, 04:48 PM
Rob,
You driving that thing yet? The weather is great! Time to drive
EdwardBlume
Jun 28 2010, 10:28 PM
foam padding and the gas tank installed...
Shout out to McMark for sealing the gas tank... very nice work!
DanT
Jun 28 2010, 10:37 PM
and I haven't forgotten about the antenna part....I promise to get it out to you
tod914
Jun 28 2010, 10:45 PM
Looking super Rob. Love the color.
EdwardBlume
Jul 17 2010, 07:03 PM
Got some work done today... installed the top dash, lower dash, painted the wiper arms, and installed (but didn't connect) the battery...
Also trying to reupholster the rear targa pad, but may need to buy one....
Lennies914
Jul 17 2010, 07:23 PM
Looking great Rob. "Dad's car" is turning out awsome. Looking forward to seeing it and meeting you in person.
Are you working on it tommorrow?
I got a little busy after WCR, but haven't forgot about the RV repairs.
EdwardBlume
Jul 17 2010, 08:08 PM
QUOTE(Lennies914 @ Jul 17 2010, 05:23 PM)
I should be around.... what are you up to?
EdwardBlume
Jul 18 2010, 02:59 PM
Its picture day.... celebrating near external completion...
