QUOTE(Eric_Shea @ Feb 23 2010, 03:46 PM)
Depends... you have a 72. Do you have late model ball joints or early? Do you have late model 911 struts or early?
Ball joints will be strut dependant.
Tie Rod ends are the same. Using a proper pitch fork you should be able to get them loose without destroying them.
it's a late 72, wedge pin. the 911 front end I'll be bolting on is off a 73 911 (boge struts)
I was less worried about the tie-rod ends, I think I could tap those out with a punch or the side.
the ball joints are tougher. I was thinking those might be able to be done by removing the top pin, hten tapping the A-arm then doing the bottom castellated nut last.
