While trying to build a 547 type fan for my engine I ran into a problem
The exhaust temperature were showing at times the cylinders were not
firing! Change the carbs to different type single barrel to dual barrels
problem was still there. So I went with Megasquirt to control the fuel
and timing. To make a long story short, I had prtoblems and this is what
I found to fix it. Now I can go back and fix the air flow problem on #2
cylinder.
