I had this tire rack custom made for my trailer. It has cross bar mounts so that you can run a steel bar through the tires and lock them in.
Also comes with a custom made cover that goes over the tires and keeps them out of the sun. This is a very tight fitting cover that doesn't blow around in the wind.
I have 5 gallon gas holders welded to either side. I can grind these off if you so choose.
The rack is painted white, unlike the picture which shows the trailer before repainting.
$125.00 fob Los Altos.
