QUOTE(gasman @ Feb 26 2010, 08:05 AM)
What should my vacuum gauge reading be at idle on my 76 2.0??? AAR good, all new hoses, dwell & timing good. Also, what kind of reading would you get if the valves are too tight??? Thanks
Vacuum readings on the 914's at idle can vary quite a bit, depending on the state of the engine, type of crankcase ventilation system (or lack of), idle speed, engine temp, etc. I typically see 13 in.Hg of vacuum (@1300' elevation) on my recently rebuilt stock 2.0L, oufitted with 1974 2.0L injection components, fully warmed up and at 1000 rpm.
There's enough variation that I'm not sure you can unambiguously detect if your valves are too tight or loose.
