I have a pair of bump stops that came with front shock inserts. Are they usable for rear shocks?
Thanks in advance
McMark
Feb 26 2010, 03:27 PM
Sure, but why?
Mike Bellis
Feb 26 2010, 04:17 PM
Make sure the bump stops are installed correctly before you jump the car. Also check that the bump stop mounts are correctly tied into the chassis or they may bend upon landing. This could cause major frame dammage or break the car in two...
kkid
Feb 26 2010, 04:44 PM
OK guys, I am talking about this rubber whatever it is called. They came with new old front koni and I did not use them since the one in the car was still good. And now I have older rear koni and plan to change with stock boge. But I don't see the rubber bump in the bode right now. So I am wondering if these front rubber bumps can go there.
