It looks like I'm putting together a deal on a Celette. I'm seeing a need for this up here in the great white north more and more.
We have a couple guys right now that could use a very light adjustment to square their chassis'.
Turnaround89 introduced stress in his chassis while welding in chassis stiffeners.
jmill purchased Very very rust free car with a hit to the right front. He has been able to get the front corner pulled back down but now the passenger door is tight.
This is not impossible to fix but even by adjusting the door opening both cars above could have the front suspension pickup points displaced.
Sir Andy's Red car is a clear example of what happens to a "Unit" body car when it is improperly repaired The car "looked" fine. But when Andy tried AX the car it was cocking the front wheel in the air. Some of the best guys around 914World were lending advise but nothing Andy was doing would help. He decided to have the car benched and discovered the car was fudged both front and back. This was the right thing to do. Now the car has a correct chassis and when adjusting the suspension he will get predictible results.
Porsche designed these cars to be repaired on fixtures. No matter how much advise I try to give guys about how to tweek the car back in shape I think were just recreating Sir Andy's car.
The other thing I noticed is guys replacing the rear suspension pickup points with a tape measure. You can do it. It will be as close as the fatigued ear was prior to the rusted one that was removed. But this most likely will be a repete if Andy's car. Sorry to keep using your car as an example Andy. But you eventually identified the issue and had it corrected properly.
Then there's the issue of replacing longs and repairing damage.
Fixture rental for the 914 is still possible and the cost is reasonable. I think with Fixture rental and my labor I could fix the easy stuff for $ 400.00-$ 600.00. I was thinking if over time there were a couple guys that have cars that need light work we could have a weekend event here. BBQ, Bench Racing and chassis work.
Here's a copy of the fixture setup. Notice these locat the transaxle mounts as well as the proper location for the 6 mount.
