QUOTE(kkid @ Mar 1 2010, 08:03 AM)
QUOTE(detoxcowboy @ Feb 28 2010, 09:24 PM)
You will only ever find the small one in the correct size. Metric Copper Sealing Washers are available alot of places but your right the OD or the ID will always be off, So like you I could never find the perfect size so I made one out of one they are cheap so you can screw one up or two.. TIP of the day: Anneal Them same as for exhaust copper rings.. heat them up with a blow torch or your stove first let them cool off.. to is softens them for a better seal..
What is the OD/ID of the larger wahsher? I will try to look in another country where metric is standard.
Is the washer solid copper just like the exhaust gasket or crash type like the oil drain washer?
Thanks
Hello Yuki,
They are solid, the outer diameter for both is .630 while the inner diameter for the smaller is .325 and for the larger is .400 with a thickness for both of .044.
Slightly smaller inner diameters can be opened but larger outer diameters will be a problem, slightly thicker should not make any difference.
Thanks for your help.
Mike
PS: thanks d_c_boy for the tip!
