So my six sat for most of the past 10 years. I want to get it driveable and given the period it sat, thought some things needed to be done first. The car started, ran and drove when I bought it.
I want to pull the gas tank and have it reconditioned -boiled out and sealed, and then replace the filter sock, rubber lines and gas filter.
It has been years since I turned a wrench; but I am willing and able. How big a task is it to remove the tank and replace the lines? How do you get the existing gas out, about 1/2 tank? What do you do with the existing gas in the tank - assuming it is likely bad gas?
I have a local radiator shop that boils and seals tanks so that was my plan for that part. Thanks for the suggestions/advice and hopefully step by step DIY guide. I am excited about getting to work on this car.
Cairo94507
