QUOTE(rick 918-S @ Mar 2 2010, 02:13 PM)
I missed something. Are you talking about a rebuilt engine or are you talking about a engine that hasn't been started for a while?
Old engine: Valve seat failing or valve burnt?
Intake valve too tight?
Fresh rebuild, running engine on a stand.
Snuck out to the shop and pulled the cover. One of the nice things about working from home.
Not sure if it was too tight, just set it anyhow. BUT damned if the lock nut on the exhaust side on No 2 was loose and spinning freely. Will check the other side and run all the valves when I get in the mood. Its a lot tougher with the sheet metal installed. And setting them once its in the car, well, i forgot what a F-r that is.
