MJ914
Mar 4 2010, 01:14 AM
Hi Guys, I have a 914/6 with early 911 BOGE front struts. I have been told you can drill out the welds and raise the spindles. I have drilled out the welds but the diameter changes in the tube at the point the spindle currently is.
Can the spindles be raised on these struts or do i need a different type???
See attached pics. Thanks in advance....
ChrisFoley
Mar 4 2010, 05:17 AM
That method only works on Bilstein struts.
At Tangerine Racing we cut the tube below the spindle and add a section of tubing, then cut the tube below the top threads and remove an equal section of tubing.
Its a little more involved than that but that's the basic concept.
ME733
Mar 4 2010, 07:09 AM
..........Question for RACER CHRIS......When the spindle is raised...what will that do , what affect will it have,with respect to,CAMBER changes, TOE setting changes, Castor changes,....during the movement of the suspension,(up or down), and steering input.......thank you. Murray.
jmill
Mar 4 2010, 08:54 AM
I'm not Racer Chris but I'll give it a shot. IMHO the beauty of raising the spindle is that you lower the car without affecting the lower A arm. Caster and camber would remain the same because those angles stay the same. You have the same suspension travel. Obviously your limited by tire to fender clearances and the chassis to ground distance. You will need to correct the tie rod geometry. There are several kits out there to do that. I've found that having the A arm and tie rod parallel limits bump steer.
sww914
Mar 4 2010, 10:55 AM
You can change the camber when you raise the spindle. You can put the spindle in a mill and add or remove camber and weld it all back together.
Rebel Racing has the nicest bump steer kits IMO. He also has struts however you want them.
http://www.rebelracingproducts.com/Suspension/Steering.html
ChrisFoley
Mar 4 2010, 11:48 AM
QUOTE(jmill @ Mar 4 2010, 09:54 AM)
Yes.
Assuming no other changes are made, the front end of the car is lowered by the amount the spindle is raised and the rest of the geometry remains the same.
ChrisFoley
Mar 4 2010, 11:52 AM
QUOTE(sww914 @ Mar 4 2010, 11:55 AM)
Rebel only does this on Bilstein struts IIRC. It is a bit tougher to re-camber a Boge strut.
We bend the steering arm down by the same amount as we raise the spindle to obviate the need for a bump steer kit.
sww914
Mar 4 2010, 11:57 AM
You're right, you can only do it on a Bilstein or if you replace the tube with a straight piece. I didn't calrify.
ME733
Mar 4 2010, 04:34 PM
...............Very cool........Thanks guys.
MJ914
Mar 4 2010, 04:43 PM
QUOTE(sww914 @ Mar 5 2010, 02:55 AM)
http://www.rebelracingproducts.com/Suspension/Steering.html Thanks Racer Chris... I'll try a cut and shut on this strut first. If that's
not succesfull, I guess I'll have to locate a couple of bilsteins.
ArtechnikA
Mar 5 2010, 06:43 AM
You probably know this already but the ultimate limit on how far you can go is when the bottom of the A-Arm hits the rim. For 15" wheels you get 19-20mm to play with. With more wheel diameter you get more room to play, but they there may be interference issues with the outside of the strut and the inside tire sidewall.
Measure -everything- to avoid head-slapping moments of disappointment later...
Eric_Shea
Mar 5 2010, 09:33 AM
You can also raise the spindles on Koni Struts. They go "right" to the flange. That is almost exactly 18mm.
MJ. As Rich states, make sure you've measured and know what you're looking for here. Anything beyond 18mm "will" have the bottom of the ball joint scraping a 15" wheel as an example.
Also, this is a job that should be left to experts like Chris. I've had a pair done previous to my purchase of them. The weld looked great but, it did not penetrate the "tube" properly. Time for more welding and RS gussets on that pair.
