Porsche914blue's thread on intermittent wipers mentioned pulling the wiper rack for lubrication. My wipers seem to have two speeds, slow and slower. I wonder if this could be a lube problem since I have never lubed them.
I read the Haynes manual procedure for disassembly and I hate the thought of pulling the motor and motor drive shaft which then allows you to pull the linkage and wiper drive shafts. My question is, could you adequately lube the wiper system with it in place? Could you remove the wiper arms and oil the shafts from the widshield end and then oil the linkage joints? Or should I forget this, bite the bullet, pull and disassemble the whole thing, and use moly grease per the Haynes manual?
Mike
