Car sat for about 6 years in an unheated garage...Master Cylinder was shot. I installed a new 17MM ATE master cylinder. Brakes have been bled twice using the helper system (pump...crack bleeder valve while holding petal down, close, repeat). I connected a clear plastic hose to the bleeder nipple and saw NO air bubbles the 2nd time around (and very clean fluid). Plenty of fluid in the reservoir. Used DOT 4 fluid.
Pads and rotors all look good. Emergency brake system works very well.
I spun each wheel and had someone hit the brakes to confirm that the calipers were not siezed.
Took the car out a few days ago and hammered the brakes from about 35MPH several times. There was no pull in either direction. The brakes were reasonably effective but seemed a little sluggish. Does it sound like the calipers should be rebuilt?
I am not sure what I should expect with a 36 year factory brake system and my expectations may have been set too high
Any suggestions before caliper rebuilds would be appreciated.
Thanks,
Bob
