Grrrr! Ok, when I jump across from pin 30 to 87, I have power to the fuel pump lead. There is 12+ volts at pin 30 AND pin 85. I have tried at least 10 relays, and they work for the fan socket. There is no signs of melting and just a little cracking in the "goo" underneath the board itself.
Is there some other "trigger" in the circut that I am missing? I have printed out the wiring diagams (color even) and am slowly going MAD I TELL YOU MAD!!!
If anybody has a fault method they would like to share with me? Or even better, a work around that I can use for this weekend to move past this issue? I promise to order a rebuilt board later this week.
Jet D
1974 converting from a 1.8 carbed application to a 2.0 fuel injection.
Trying to use stock wiring. Not too badly "skunked" by the PO
Thanks
