Does anyone have a fix for repairing the tab or clip on the backside of the horn pad in the center of the steering wheel? I found the wire that comes thru the column laying in the center of the wheel hub with the clip stuck in it - broken off from where it attaches. Would drilling a hole in the aluminum plate and putting a bolt and nut on it to hold the wire work? Car is a '74
Maybe someone has a better idea? Thanks for the advice.
