QUOTE(nycchef @ Mar 10 2010, 11:33 PM)
QUOTE(Eric_Shea @ Mar 10 2010, 08:11 PM)
Loosen up all your other bolts and start over.
what size bolt do i need
Google "Porsche Parts PDF" Pull up your car and have a look.
a drop of advice in a sea of foolishness. thanks eric, will give it a try
Do yourself a favor.
Drop the rear bolts out first.
lower everything.
Get a tap and chase the threads on the front holes. (and clean them of rust...and paint them you fool...use a brush)
Jack everything back up and put the FRONT bolts in first....and make sure they are loose.
Then put the two big rear bolts in.
You could be getting hung up on the steering shaft also if you have the rack bolted in place already....so unbolt that and let it slide around while you get the a arms hooked up first.
Sway bar...unbolt it
Top of strut...unbolt it.
The first bolts need to be the a arm bolts.
Start at the front (did I repeat that)
The the rear...you can lever the rear easier.
Then the top of the strut
Then the steering rack (after the a arms are tight)
Rich
