QUOTE(Dave_Darling @ Mar 10 2010, 06:58 PM)
When you open or close the headlights, do they go all the way to what you think is the "normal" closed position, then go back up again? If so, you need to re-position the linkage arm on the motor.
If this is as far down as the light goes, then you need to loosen up the whole assembly and tilt it in place. There are a number of bolts and/or allen screws that hold it in place; you can get some adjustment out of them if you loosen things up.
--DD
Thanks Dave.. its the latter.... it is off the same height throughout the rotation.... So loosen the bar bracket? shove it down into place? It kinda seems to like where it is, but its almost an inch too high... odd...
