dflesburg
Mar 11 2010, 05:52 AM
should the distributor vibrate at idle?
4 cly engine?
TheCabinetmaker
Mar 11 2010, 06:09 AM
Absolutely not! Sounds like its not seated all the way
Mark Henry
Mar 11 2010, 06:21 AM
Remove the dizzy and check for shaft wear (play), my bet is it`s worn.
If you've had tuning issues this will be the (main) reason.
It should only have only about .015-.020 play up/down and no play side to side.
Katmanken
Mar 11 2010, 08:44 AM
It shouldn't vibrate any differently than the engine in which it is mounted.
dflesburg
Mar 11 2010, 10:21 AM
indeed.
I believe that what i am seeing is due to the fact that I am now wearing tri focals.
My mom always said if I didnt stop doing that I would go blind....
