BMXerror
Mar 13 2010, 09:05 PM
Hey guys. I used the 'search' feature but couldn't quite find what I was looking for. I want to know the diameters AND effective lengths of the stock swaybars, front and rear. I'm doing more suspension calculations that are over my head, and I want a good factory point to start from. Thanks in advance.
Mark D.
BMXerror
Mar 14 2010, 10:06 AM
Eric_Shea
Mar 14 2010, 01:24 PM
15mm diameter and 98cm long (around 33.5")
BMXerror
Mar 14 2010, 03:44 PM
Thanks... Is it the same for front and rear?
Mark D.
Dave_Darling
Mar 15 2010, 12:03 AM
The rear is 16mm diameter, but the length is a little more tricky. The bar is bent (small bends to fit along the trunk floor, and the bends to make the "arms" of the bar) so I'm not exactly sure which length is the appropriate one...
--DD
BMXerror
Mar 15 2010, 12:46 PM
Is it tubular? I could probably approximate with a measurement from where it starts to bend for the arms to the same point on the other side. Thanks for the info, Dave and Eric.
Mark D.
