kfish914
Mar 13 2010, 10:57 PM
Does any one know the size of the pulley shims for a 2.7 six. I quess the PO needed them more than I did becasue the engine does not have any. I know i can order them for around .80 however i don't want to pay ten bucks to have them shipped to my house when the local hardware store has a whole bunch of different sizes. They call them machine washers. So if any one has one to measure I would find it most helpful. I have searched the internet and can not find the information.
Also I need the size of the banjo bolt (911 110 899 00) that goes into the start valve if any one knows that also.
Cap'n Krusty
Mar 13 2010, 11:27 PM
There are 4 different shims that I know of, and NONE of them are available anywhere but from Porsche or one of the aftermarket specialty sellers. At least one diameter is NLA new. The Cap'n
kfish914
Mar 14 2010, 09:08 AM
Thank you for the response.
I was hoping to be able to get them with out paying three times the amout for each one because of shipping.
The local FLAPS told me they could get the banjo (hollow) bolt if i knew the size. Which I would like to do because one internet supplier wants $17. dollars just for the bolt, yes ONE bolt, and another $12.95 in shipping
Poor man's Porsche my a**.
Cap'n Krusty
Mar 14 2010, 09:34 AM
Have you asked us here for the bolt? I have 2 2.7 FI systems for parts, and may have what you need. I need to know exactly where it goes, however. A FLAPS is NOT a good place to look for Porsche parts. The Cap'n
kfish914
Mar 14 2010, 09:50 AM
I had not asked for the bolt from the here. I didn't even think about it for some reason. I quess i was thinking I could find it local. My motor is a 74 2.7 with CIS and form what i can see when the PO took the engine out of his 911 to do a 3.2 they unhooked a lot of the lines on the intake so I have been slowly trying to get it all back together. I will look up the part number and send you a PM.
sixnotfour
Mar 14 2010, 10:14 AM
The PN is for a banjo bolt for the injector lines on top of the fuel distributor.
The shims depend on which fan you have , If its early style (big pulley)
the shims are cheap and the same as 911 cam shims.
I am sure the Captian can help you
kfish914
Mar 14 2010, 10:58 AM
Thank you. I'll touch base with the Capn.
