skipnsb
Mar 13 2010, 10:57 PM
GM says the base engine for the new Camaro is a direct injected all aluminum dohc v6, 304 hp and 350 pounds. (Same as the Cadillac "Newstar" and a bunch of others, its the new GM corporate v6) but now direct injected. Forged crank/rods.
It seems like this might weigh less than the 230 hp Subaru SVX engine I already bought, and be shorter and lighter than the LS1/sbc.
A factory docile/flat torquey 304 hp with a 901 would seem a good match.
Kennedy has the conversion flywheel/adapter.
Since this is the base motor for the new Camaro, I predict they will be more available in junkyards soon and I expect the aftermarket will offer some performance upgrades quickly.
Has anyone considered this (or the Cadillac etc.) engine? any thoughts? width?
Thanks Skip
Dr Evil
Mar 13 2010, 11:44 PM
I am not so sure a 901 would be a good match for this motor. Although it is not the least expensive way to go, a 915, 930, Pantera ZF or stronger will give you better service.
burton73
Mar 14 2010, 06:02 AM
Skip,
Beside the point Dr Evil made on the 901 match, the price of these engines will not be that low for a long time. I think the point was the Subaru SVX had its weight lower balanced as it is a boxster style.
You can just add 100 lB more and add 150 hp with the LS1
Bob
quikshft
Mar 14 2010, 10:32 AM
QUOTE(skipnsb @ Mar 13 2010, 09:57 PM)
Thanks Skip
I'm new to the forum but am reading and learning a lot and am planning a build myself. What is appealing to me about the Subaru transplant is that there is a fairly inexpensive option for a transaxle, that being the AllWheelDrive Subaru 5speed converted to what amounts to front wheel drive. Now if you could mate that Camaro V6 with the Subaru transaxle we might have a winner.
Dr Evil
Mar 14 2010, 11:57 AM
Indeed, that might be a great match.
Andyrew
Mar 14 2010, 02:48 PM
Dont get stuck on a Subaru trani, There might be better options out there.. Like an Audi/VW FWD trani, They use transaxles and are known to be very strong.
That being said the 304hp V6 chevy engine in the current camaro is a killer engine, Drove it and its pretty quick and revvy. But the cost on that motor is just way to high right now to be justified in an engine conversion. 5 years? maybe.
