srohling
Mar 14 2010, 10:30 AM
Just got my motor back and installed. I installed a duel pickup sender and have the hose extension kit installed as well. Also installed a new VDO Oil pressure gauge. Upon my first starting the motor, I only showed about 20 lbs of pressure on the gauge. I called my engine builder who said it showed 50 lbs + when he did his break in. I blew the hose out with air and cleaned the hole on the sender. The gauge now shows about 30 lbs of pressure....you guys have any ideas of why I am not getting a better reading? This is a brand new motor with the big oil pump. Could it be a voltage or grounding issue?
as usual...you guys are always a big help.
Scott
VaccaRabite
Mar 14 2010, 11:07 AM
Are you sure that the sender is properly grounded to the case? The sender is meant to ground by screwing into the case. when attached to a remote hose, the hose blocks the ground, or partially blocks it. How have you gone about making sure the sender was grounded to the block?
Zach
pcar916
Mar 14 2010, 02:07 PM
This is a little like asking someone "if it's plugged in" so forgive me ahead of time, but are you certain the gauge and sender are a temperature-range match?
Good luck!
underthetire
Mar 14 2010, 02:29 PM
my guess you have a 150PSI sender with a 80 PSI gauge.
srohling
Mar 14 2010, 02:42 PM
All good answers everyone. I have grounded the the sender by using the metal bracket which is supplied and attaching with one of the case bolts. I don't know about the 150 lbs Vs. ??? lbs sender...I have to check into that one.
Thanks, you have given me a little direction.
Scott
srohling
Mar 18 2010, 06:07 PM
Ok...after waiting for AA to get back to me on the sending unit, I got tired and ordered an 80 PSI VDO sending unit from Summit. Plugged in and reading 55+ PSI. BTW, the Summit unit was a good deal less than the cost at AA.
