flipb
Mar 15 2010, 10:45 AM
I'm debating whether to upgrade to electric - curious about the "state of the fleet" with this equipment.
tracks914
Mar 15 2010, 10:56 AM
Spare tire pressure on both cars but neither has ever been hooked up....yet, I just drive on sunny days.
iamchappy
Mar 15 2010, 11:03 AM
I use the electric upgrade and RainX
Shade Tree
Mar 15 2010, 11:40 AM
Have the parts to change it to an electric Suzuki Samurai set up. It's just lower on the list than like 85 other things. For instance, I decided I was finished tuning the engine Saturday evening. Got out of the car after the test drive and broke the door handle....I can't keep up.
PeeGreen 914
Mar 15 2010, 11:42 AM
I just use rainX and actually rarely need to use the wipers
Mar 15 2010, 11:45 AM
911 (same as 914-6) electric pump with the stock bottle and stock intermittent relay.
Andy
JmuRiz
Mar 15 2010, 12:06 PM
I don't use mine, really only be in rainy weather 2 times. I use rain-x and will probably remove them all together when/if I do bodywork (along with reflectors and antenna).
Van
Mar 15 2010, 01:23 PM
I don't use mine, but it's because I know how the system works... the washer hose goes up the steering column and is "pinched" to turn off... It's only a matter of time before that old, dry-rotted rubber hose breaks and I have a lap full of washer fluid!
Zundfolge
Mar 15 2010, 01:36 PM
I use the optional "driver's seat monkey with a spray bottle and rag" (usually use newspaper though, not a rag).
flipb
Mar 15 2010, 01:49 PM
So nobody still risks the lap squirt?
My reservoir is relatively full, but the air hose to the spare won't hold pressure. Wonder how old that fluid is.
ME733
Mar 15 2010, 02:51 PM
........very soft rag....WINDEX......dry.....very soft rag....RAIN-X....DRY, rub in ....but it,s now just my good weather garage queen...., until I hit the twisty- back roads.....(gotta check the deer whistle) before my next excursion.
markb
Mar 15 2010, 03:15 PM
QUOTE(iamchappy @ Mar 15 2010, 09:03 AM)
Me too.
ArtechnikA
Mar 15 2010, 03:29 PM
6's came with electric...
In SoCal I almost never used it.
Here in SEPA I do, almost every day, especially in slush season with so much muddy spray. And a lot more diesel traffic.
in the ur-GTI I ran hoses and nozzles directly to the wiper arms, WRC-style.
jt914-6
Mar 15 2010, 03:33 PM
Have a bottle/pump combo in front with an adjustable intermittant wiper switch. I also use Rain-x.
turboman808
Mar 15 2010, 03:37 PM
stoners and a microfiber towel works better.
I try not to get the car wet.
turnaround89
Mar 15 2010, 05:39 PM
my car sits on jackstands, so no point in cleaning the windshield
i upgraded to an electric pump, works pretty well...but when i did have a driveable car, i wash it so often, i hardly every used the washers
Pat Garvey
Mar 15 2010, 07:35 PM
So simple. Just keep the spare pressurized. Works like Ferry meant it to.
Pat
KaptKaos
Mar 15 2010, 07:39 PM
Rainx
VaccaRabite
Mar 15 2010, 08:24 PM
The squirters are installed for looks only. Non of the other bits to make it work are hooked up.
It gets RainXed a few times each season, and that seems to work fine.
Zach
bag5rcg
Mar 15 2010, 08:48 PM
Rain-X baby
swood
Mar 15 2010, 10:36 PM
Rain?
BarberDave
Mar 16 2010, 06:46 AM
ME733, I just couldn't let this pass. Do you check the dear whistle often,
what is your record ,how many dead dear have you found under it.
My spare won't hold air. so the washers don't work. RainX is the ans.
and the old seat monkey.
I once drove home from Hershey in the Rain , be cause of the RainX
rain just blew off. Dave
VaccaRabite
Mar 16 2010, 11:02 AM
Yeah, RainX is magic stuff. I put it on all my cars whenever they get washed (and usually end up washing my cars when I notice that the RainX has all washed away).
You almost don't need wipers when the stuff is on and working.
I use RainX on the outside, and FogX on the inside (since I have no heat either).
Zach
naro914
Mar 16 2010, 11:10 AM
914's had windshield washers? Really?
Oh, is that what the little holes near the windshield are for??
watsonrx13
Mar 16 2010, 03:24 PM
QUOTE(Phoenix 914-6GT @ Mar 15 2010, 12:42 PM)
Ditto...
-- Rob
70_914
Mar 16 2010, 06:14 PM
QUOTE(Vacca Rabite @ Mar 16 2010, 10:02 AM)
Don't use RainX on Bug windshields.....
I found out how well window stripper works after that mistake. There is no wind blowing the rain droplets off the flat vertical windshield due, if my slight knowledge of aerodynamics does not fail me, to the high pressure zone right in front of the windshield.
Anyway.... on bugs RainX is not magic stuff it is the devil.
And to answer the question - I run the spare tire air and cuss at the poor performance, just like the good Dr. intended.
charliew
Mar 16 2010, 08:12 PM
When I redid my son's 72 super beetle I replaced the lines with plastic and new rubber, it seems to work just like it did 25 years ago. I will probably do electric on the 914 though.
