Scott S
Mar 15 2010, 12:07 PM
Hi All -
does anyone have a pictured of the Rich Johnson -6 mount showing the rear brake proportioning valve installed? I just realized that all the pics I have of the installed mount dont show the valve installed.
Is it even an issue? Does it need to be removed to install the mount?
Thanks!!!
Scott S
J P Stein
Mar 15 2010, 12:24 PM
Yeah....here somewhere.....ah....oops, not a stocker. IIRC, it used the original holes tho.
Eric_Shea
Mar 15 2010, 12:27 PM
It depends on the year car. Mid 74 carried the new location for the "emergency pressure regulator" valve.
From mid-74 on they need to be moved.
I had to move mine:
I need to do a little line work now. I mounted it in the wrong spot. I should have put it on the rib.
Scott S
Mar 15 2010, 01:24 PM
Thanks a million - I got a bit nervous for a second....
Edit -
It appears look at Mr Shea's car that even though I can retain the facotry valve, I will have to pull the lower line off to thread it through the mount - is this correct?
My brakes are really great. I will do what I have to do, but would prefer not to open the system if possible.
Eric_Shea
Mar 15 2010, 02:17 PM
Yup. Goes through that hole.
That's the later style line so I left in on there when I painted. I'll need to get the longer early style line now.
