QUOTE(904svo @ Mar 16 2010, 05:52 PM)
The only place to get the real head temperture is under the spark plug, any
other place will take too long for it to show the real temp. If it gets over 400F
under the plug you are taking chance that you will drop a valve set real quick,
while other spots on the head will not show this right away.
I agree with the lag, but the only thing that will fit under the spark plug that i've seen is the thermocouple setup. That won't work on the megasquirt. The VDO one has too many cold joints in it, and does not use the K TC wire to the sensor, just an extension wire. I'm sure the Dakota one is better, but i'm sure it's still a TC, and TC's just are not as accurate as a thermistor. I think the best way would be to pot a thermistor right next to the plug.
