QUOTE(bandjoey @ Mar 17 2010, 12:07 PM)
Another curious minds just want to know:
Why replace the shaft? If the bushings are not totally worn out, where would the shaft wear? Or is it just the money thing. bushings and shaft for the cost fo bushings?
That's not a new shaft, just a replated stock unit I bet.
The shafts don't wear out they rust out. In the Northeast they are all usually NFG when removed. That's just one of the reasons I started offering relacement shafts, with oem style mounting studs (not drilled and tapped for bolts).
IMO, those shafts in the auction aren't true enough for Delrin bushings.
