QUOTE(roberthbollinger @ Mar 17 2010, 02:57 PM)
Hello:
My 1973 914 2.0 backfires/pops on deceleration. My mechanic replaced the aux air regulator and the car now idles properly after re-starts when warm. The head temp sensor was replaced, the valves and timing were adjusted and the vacuum lines were re-routed (with the factory workshop manual schematic). The car has been checked for exhaust leaks and I don't think that is the problem. My mechanic also tested and adjusted the the throttle position switch. The car is stock accept for a Pertronix Ignitor (installed after the poping/backfiring was an issue). The pressure sensor has been evacuated and checked. The pressure sensor on the car is a 1.7 litre Bosch part # 0280100049. The car was built in 11/72 as a 1973 model. The four fuel injectors have been replaced because one was leaking. The poping/backfiring began after this repair. Should the injectors be cleaned and/or replaced? Should I go back to points and condenser? What is causing the car to run rich on decel making the car pop/backfire?
Thank you, Bob
I would agree with you that you have the "wrong" sensor. But when you take your foot off the gas, vacuum increases, the cells expand, and the diaphram seats onto the part throttle stop. When MPS's are operating in this region, they are pretty much the same. Take a look at Brad's calibration chart. Four MPS, and yet at 15" Hg, their inductance is .72, .72, .71, and .71 H. The significant differences come in when the diaphram starts to rise off the part throttle stop- when it starts, transition slope, and how far it goes before it hits the full throttle stop all tune it to the needs of part and full throttle operation.
So with your sensor, I would probably expect lean miss at part or full throttle, and/or hot running at full throttle. Of course, if this is mitigated by something, like higher fuel pressure, then you may seem to run fine at part/full throttle, but then too rich on idle and overrun. And if you're too rich AND your timing is retarded, then the popping could result.
So I'd probably check fuel pressure first. Followed by timing. Is your distributor retard hooked up and operating? Out of curiosity, what's your idle vacuum?
Still figuring these things out myself...
Jim
