Hello,
Thursdays are my days to work on the car. Today we buttoned up all the vacuum hoses. Changed transmission/gear oil, fixed several wiring gremlins to the rear lights and installed rear bumper. We also reinstalled Engine lid and trunk lid, during final adjustment to the rear trunk lid the pivot point let go where it is mounted to the side of the chassis behind and above the battery.
The PO supplied me with the part so I was aware this was an issue but did not think it would let go.
By removing the battery and covering everything else up, is there enough room to weld the new piece back in. Does anyone have any suggestions or advice for this fix.
Rust is not an issue all, I am just not sure there is enough room to get the new pivot properly secured?
Thanks,
Vysoc
