I recently disassembled my speedometer to fix the Odometer per Pelican's instructions. I also corrected some wiring irregularities on the gauges. Doing all this late at night, I didn't get a chance to take my 914 our for a test drive.
This morning I ambitiously planned to drive to work - something about 70 degree afternoon forecast got the better of me.
The first thing I noticed was that the e-brake indicator/flasher won't go off. It's not the button on the handbrake, as I can depress the button all the way with my finger and the dash light continues to flash away. It got so annoying on the way to work that I eventually pulled off and disconnected the lead from the back of the combo gauge.
Second, my Odometer "Fix" hadn't worked. Odo wasn't rolling.
Third, my speedometer has a new issue... at low speeds, the needle jumps periodically all the way to the 150mph+ range with an audible "pop". I know it's mechanically driven but the popping sound had me worried that something was shorting out back there and causing it to jump... Now I think I've ruled that out, and my guess is that I left something too tight when I tried to fix the Odometer, and the speedo drive is struggling to overcome some friction inside the gauge. Is this a common problem? Time for a professional gauge rebuild or a replacement gauge?
Any help appreciated... especially if it's something I can do in the parking lot at my office before the drive home this afternoon!
