QUOTE(SirAndy @ Mar 19 2010, 10:39 AM)
I see front wheel spacers in your future ...
Andy
Ya, whats up with that? i measured and had put my friends rims on and they did not look that far in... same offsets and everything! I don't get where I went wrong, oh well.
Could it be that fiberglass flares stick out further than steel since they are bonded on the fender instead of replacing the sheet metal. I also read that fiberglass fenders allow wider wheels. Awesome motor!
Been working on the motor. It started life as a '73E engine, 3R/4R case. I machined it for the oil bypass mod, welded one cracked head stud and machined the cylinder true and decked them.
-Heads: bored 36mm Int/Exh, ported, polished on the exhaust. Twin plugged, new guilds, valves, Eibach springs, and titanium upper retainers.
-Crank: inspected, micro-polished, center oil main drilled for connecting rod 2&5
-Cylinders are Mahle 92mm RSR pistons and cylinders, purchased in the mid 70's.
-Cams: Dougherty DC60's
-MFI pump rebuilt by Gus, Pacific FI to 2.7RS spec. I rebuilt the mfi stacks, bored them to 36mm on the throttle body, and 40mm on the plastic runners. Machined new aluminum linkages for butterflys.
-Carrera chain tensioners, Supertec head studs, see through RSR fan shroud, Patrick twin plug rotor, MSDS multiple spark.
Thats all I can think off at the moment. heres a pic.
