QUOTE(ConeDodger @ Mar 20 2010, 12:05 AM)
QUOTE(McMark @ Mar 19 2010, 07:45 PM)
Paper gasket?
Blue Silicone?
It is always good to get some of that in the oil passages too
.................WELL to bad you cant read.Try reading my post again., the blue rtv silicone engine sealer goes on the OUTSIDE of the oil cooler seals....and the paper gasket goes between the engine case and the oil filter mount....that should have some sealer on both sides....But in YOUR particular case, with apparently and OBVIOUSLY your lack of experience, finese, and common sense YOU should NOT use any sealer for the reason you stated....YOU... will get it into the oil passages when the mount , or cooler is torqued down...............murray
