QUOTE(kwales @ Mar 21 2010, 11:41 AM)
I think you need to know this important difference between carbs and fuel injection, and what effect a cam has on this.
Fuel injection squirts all of the fuel needed onto the closed intake valve. When the intake opens, and the piston is moving down, this fuel squirt is the first thing sucked into the cylinder and is followed by extra air that is swirled or mixed with the fuel squirt in the cylinder.
This needs some clarification....
It is 100% true, for a batch type injection system. The D-Jet and the L-jet systems are batch injection systems. They spray their fuel on the back of the valve, and it sits there until the valve opens.
It is not true for a sequential system. A sequential injection system has a cam sensor that measures the degrees of camshaft rotation and uses that to time the injector pulse so that it injects fuel only when the intake valve is open. This actually produces more power than the batch injection, as it increases the velocity of the fuel/air mixture.
Plus, the sequential injection can handle more cam overlap than a batch type injection.
Most new injection systems are sequential, as they get better mileage, more power, and lower emissions out of the same engine. Most of them are programmed to default to a batch injection on the loss of the cam sensor (limp mode).
