ILM914
Mar 21 2010, 02:25 PM
Hello all: On my 74 2.0L 914, I am not getting power to the elec injector plugs on # 1 & # 4 cylinders thus I am running on 2 cylinders. I am just finishing putting the car back togetther from a bunch of work and had it running fine yesterday then all of the sudden this? happened. I switched injector wires and the problem moved with the #1 set of injector plug/wires. No power to # 1 & 4 injectors. I took the distributor off, removed the fuel injector trigger points and cleaned them and cleaned the three ground wires on the top-back of the engine, still only two cylinders. Anyone have advise? Than you, Joe
brant
Mar 21 2010, 03:10 PM
its either those trigger points or else a break in the wires coming out of the distributor (to the same points)
I'd test the wires for continuity and then if they are good you will probably need some different lower fi points.....
you can probably test the points themselves for continuity also.
brant
ILM914
Mar 21 2010, 03:53 PM
thank you will lookinto it more
scrz914
Mar 21 2010, 06:11 PM
this is my story as well...except I have a brand new FI harness
Tell us how it goes for you
ILM914
Mar 22 2010, 12:50 PM
OK
JeffBowlsby
Mar 22 2010, 01:11 PM
Also check that all three ground wire connections are intact where they attach at the rear of the engine case.
pbanders
Mar 22 2010, 02:48 PM
If the trigger contact points, grounds, and the harness check out OK, then the problem is your ECU. Most likely it's a failure of one of the germanium power transistors that drive the injectors. See the following schematic:
http://members.rennlist.com/pbanders/ecu1.jpgThe transistors I refer to are the unlabeled pair below D502. It also could be another component failure in the ECU circuit path from the trigger contact points to the injection logic, but such failures are usually in the output stage.
If this is the case, you'll need a replacement ECU. From what I know, finding replacements for these germanium transistors is difficult, you may be able to salvage one from a scrap ECU.
Bartlett 914
Mar 22 2010, 03:21 PM
QUOTE(pbanders @ Mar 22 2010, 02:48 PM)
Sorry for the hijack
Brad. Do you know the transistor part number? I have some To3 2N2144 PNP germanium transistors and a few others.
ILM914
Mar 22 2010, 04:08 PM
Thanks folks, I'm pretty sure it's the trigger points - no power coming from the wire coming out of the 3 pin distrubutor plug to # 1& 4 injectors. Does this seem right?
underthetire
Mar 22 2010, 04:19 PM
Thought they were switched ground?
Anyway, you would really need to pull them and check continuity between the center pin and the right and left pins. They may check open in the Dizzy if the lobe has them open.
DipShit
Mar 22 2010, 04:37 PM
I had this same problem last summer and I chased it for MONTHS. Originally the Capt posted ground, I felt the strap and it APPEARED good. BUT, after months of chasing all kinds of shit it (as far as replacing the wiring harness) ended up being the damn ground strap. It was split at the bolt and did not make a solid ground.
Check and double check the ground strap.
ILM914
Mar 22 2010, 08:53 PM
Thanks will check again but everything is really clean and tight, just put engine and tranny back in after overhaul. Good idea though I'll check again, may have missed somthin. I am almost sure it is one side of the trigger points in the dizzy.
dflesburg
Apr 4 2010, 11:44 AM
Did you find it?
Our car isnt running 2 or 4.
blowing lots of fuel out exhaust
can get it to idle new plugs points condensor rotor.
at idle pull each plug wire one at a time 2 and 4 make no diff pulling 1 or 3 make it die.
