Full Version: HELP! 914 Voltmeter VDO Gauge connection
recko911
Can anyone let me know where do I connect the Voltmeter VDO Gauge so I can get the best reading... I am not to familiar with the electronics.. Is it in the fuse panel thanks...
Mike Bellis
QUOTE(recko911 @ Mar 21 2010, 08:36 PM) *
Can anyone let me know where do I connect the Voltmeter so I can get the best reading... I am not to familiar with the electronics.. thanks...
For the best reading, run new wires to your battery. Any 12V+ switched wire will give you a good enough reading. Automotive voltage gauges do not have a fine enough callibration to worry about. You can compare the reading with a digital voltage meter (like a Fluke).
Just make sure your system reads between 13-14 volts at 2000 rpm. Most vehicle electrical charging systems do not make good voltage below 1500 rpm.
Cap'n Krusty
The battery is the best place, but you'll need to run it through a relay or it'll be on all the time. The Cap'n
