QUOTE(Frost @ Mar 23 2010, 01:45 PM)
Need some help, ive been doing my research and still no results. At first the car didn't start so i replaced the fuel pump, regulator, relay and fixed the ground then it started right up like a champ. When i went to test drive it i could get it to 3rd then it wouldn't want to go past 3rd and start decelerating with no control. I replaced the coil, since the friend i bought it from told me it was really old, trigger point, condensor, and head temp sensor. Went to test drive it and i could'nt even get out of first before it would start decelerating and die on me, I could drive it for a little bit after i turned the key off and the then start it but same issue after a minute.
Im narrowing it down to fuel pressure sensor, what do you guys think?
Did you pull the fuel tank and replace the fuel lines under the tank? If so, upon re-installation, one of the fuel lines might have kinked. I just went though this but my car would choke out and decelerate any time I made a turn. The fuel pump was much louder as well while this was happening. Even if not, you might want to take a look at them to be sure they're not kinked 'cause it sounds like one might be.
Just my .02.
Tom
