patssle
Mar 26 2010, 06:22 PM
I'm replacing the 2 rear bushings in my attempts to fix my shifting problems (4th gear goes into 2nd). I bought the bushings from Pelican Parts for my '76 side shifter.
When I slip the shift rod bushing over the rod, the rod is pretty loose. It's about 1/16ths smaller than the bushing.
Any thoughts to why it's so loose?
Tom
Mar 26 2010, 06:33 PM
Shift rod worn down. Found the same thing on my 76. I have a small lathe, so I made some that better fit the rod and the console where the bushing goes. Shifting greatly improved. I did get some pics posted in a thread about 4 years ago. Try the search function for shift and bushings.
Tom
patssle
Mar 26 2010, 06:38 PM
Funny. I was reading your very thread as you replied.
http://www.914world.com/bbs2/index.php?sho...c=72473&hl=I also read Rick's "make your own bronze bushing" thread. Any suggestions to places I can get something like what he used? Or are they pretty available any hardware store?
http://www.914world.com/bbs2/index.php?sho...&hl=bushing
Tom
Mar 27 2010, 07:43 AM
I didn't even try the hardware store, but I think they would have bushings or something. I made mine out of trash pieces from work. I decided to go with the delrin because it is much softer than bronze. If plastic wears the shift rod, what would metal do to it?
Tom
914Sixer
Mar 27 2010, 07:54 AM
GPR has the bronze bushing for under $20.
Krieger
Mar 27 2010, 08:11 AM
Patrick Motorsport has the one to buy. It is a very tight fight and has no slop. My shifting is very good now. I had bought a polybronze before I can't remember where but it was junk. PMS was about $35. you need to open up the hole in the tranny a little bit with a file. The shift rod was hard to install, but oh it shifts so nice I'd do it again.
ellisor3
Mar 27 2010, 09:17 AM
QUOTE(patssle @ Mar 26 2010, 08:22 PM)
You might also consider replacing all of the bushings, not just the back ones. There is one in the firewall and the ones in the universal joint. I had problem shifting as well, a tiny bit of slop in the front can add up as you get to the back.
computers4kids
Mar 27 2010, 09:26 AM
QUOTE(Krieger914 @ Mar 27 2010, 07:11 AM)
The brass one from GPR fits perfectly with no alterations to the transmission.
hwgunner
Mar 27 2010, 09:59 AM
I make the brass one (it's actually Oilite). Sold Hundreds. Call me at 800-321-5432 and I can get one out on Monday. Normally $18.95, club discount brings it to $16.95 and $485 shipping in US.
jonathan
Cap'n Krusty
Mar 27 2010, 10:06 AM
QUOTE(hwgunner @ Mar 27 2010, 08:59 AM)
jonathan
At $485 shipping, one would think you'd cover any losses from the discount .................
The Cap'n
Elliot Cannon
Mar 27 2010, 10:22 AM
jonathan
Decimal point. Ring finger, right hand, Lowest row of keys.
Elliot Cannon
Mar 27 2010, 10:24 AM
I have the GPR brass one (it's actually oilite)
on my car. Works fine, lasts a long time.
markb
Mar 27 2010, 10:56 AM
Yes, that's supposed to be $4.85 shipping.
Call us, we've got what you need.
Mark, posting from Vegas & still shilling parts.
You payin' attention there, Bossman?
john rogers
Mar 27 2010, 12:56 PM
The brass bushing work very well as long as the small bellows cover is there to keep the oil and grit out otherwise the parts will wear pretty badly. A trick we used on mine and other race cars is to get several of the very small nylon wire ties and put several through the ID of the bushing in the same direction the shift rod goes. Loop them and tighten them so they are snug and then snip off the ends. The nylon wire ties will act as a natural slippery surface that will not cause any abrasion to the shift rod.
I usually replaced all the bushings every winter as part of down time maintenance and put in new ones. You can slide a couple of the very small ones through the firewall bushing but you have to tie off the ends around the forward shift rod so they do not work out.
patssle
Mar 27 2010, 02:36 PM
QUOTE(ellisor3 @ Mar 27 2010, 07:17 AM)
My firewall bushing is pretty solid, and is brass. Not sure about the front one, need to check it out. My "Shift lever with selector rod" has its splines rubbed down, so may need a new one of those too.
